Page 37 of this manual has the fault codes:
http://www.pridemobility.com/pdf/owners_manuals/us_scooter/us_victory_10_om.pdf
SOURCE: Battery isn't charging, no handbook
be sure of model etc & order a manul from the dealer,then once read the basic guides,if no joy then book will advise you to get in touch with a qualified dealer.
SOURCE: road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
SOURCE: Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: I have a 3yr old
Kay the status light flashing indicates a problem. Count the nunber of flashes and your manual should tell you what the error code means. Also check the freewheel lever and make sure it is drive position. Without knowing the number of flashes I can't tell you what the problem might be. Hope this helps
Testimonial: "freewheel lever! thank you very much"
