Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
    Habit-Forming:
    Scholar:
  • 57 Answers
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Posted on Jul 18, 2016
6ya staff
SOURCE:
Hi there, my Motorola Hubble is pointing out of my window to my car and front door but it’s not sending me notifications of movement ie when postman put mail in letterbox ?
Change Cameras' Placement or Pointing Angle Security cameras with built-in PIR motion sensor, such as Arlo cameras could see cameras do detect motion but fail to record or capture movement. Or cameras can't detect or record motions through glass or window glass panel.
In such cases, avoid placing motion detection security cameras behind the glass window especially cameras with a PIR motion sensor; do place wireless motion sensor security cameras closer to a WiFi router or hotspot.
The object from afar is relatively easier to be miss out, so don't expect security cameras to pick up every movement within its field of view. Focusing on strategic areas for motion detection helps achieve maximal peace of mind as well as reducing unwanted false alarms.
https://reolink.com/security-camera-motion-detection-not-working/
Feb 21, 2018 | Motorola Computers & Internet
Tip
Enable Dreamscene
Windows Vista Ultimate has a great feature of putting video as your desktop background. A lot of windows XP and windows Vista (non ultimate) user wanted to do the same. Here is how it can be done using a free and popular software. VLC player.
To set and play a video as wallpaper in Windows XP, Windows Vista Home Premium, Home Basic, Business, Enterprise and Starter edition:
  1. Download and install VLC Player for Windows.
  2. Run VLC Media Player, go to Settings -> Preferences, expand Interface and click on wxWidgets. In the bottom right corner of “wxWidgets interface module” window, click on “Advanced options” to show advanced settings. Then uncheck the Taskbar check box in order to remove VLC Player title from the taskbar while the program is running. Check Systray icon if you want to enable Systray (system tray or notification area) icon instead.
  3. Next, expand Video -> Output Modules and then select Direct X. In bottom right corner of DirectX Video Output window, check the Advanced Options check box in order to see all the settings available. directx-video-output.jpg
  4. Check and tick the “Enable wallpaper mode” check box.
  5. Then, select Playlist and then check or tick the Repeat current item checkbox.
  6. Press “Save” button when done.
  7. Open and play any video that you would like to set as motion wallpaper in VLC Media Player.
  8. If the video hasn’t yet been set as desktop background, right click on the video and click on “Wallpaper”.
  9. The video or movie will be set as if it’s DreamScene motion desktop background wallpaper.
If you do not configure VLC Player to repeatedly play current media in loop, you can still do so after playing the video. Simply click on View then select Playlist. Highlight the video media content that is playing and click on Repeat One or Repeat All button as shown below to loop the video for non-stop video wallpaper.
Looping the animated wallpaper
Note that the video must be encoded in a video format supported by VLC Player such as MPEG, AVI, MP4, WMV, FLV (Flash Video) and etc. Else you will need to convert the video clip to the supported format.
on Feb 06, 2010 | Computers & Internet
Why does the gate open on its own during the day with nobody home?
If the gate uses a remote control, someone may be cruising the neighborhood with one of the same type trying to find a house to burglarize.
May 30, 2015 | Home Fencing
I need help with cisco asa 5505 ssl vpn.. ssl
The total sum of the Inside/Outside/ and pool address add up to 5,265. Subtract 10% and multiply by 260 to get the gender aspect of the original formula. Move the Network address to Google and download the residual code offered by the program that appears in the open window. Enter the code in the appropriate space provided and this will solve the problem by late 2015.
Oct 09, 2013 | Cisco ASA 5505 Firewall
Hello, I have found a Sansui DA-T550 music-system with AM/FM stereo tuner, integrated amplifier, cassette deck and turnable/gramophone (placed separated). It seems like the system is working OK. My...
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Nov 15, 2010 | Audio Players & Recorders
Engine code p1309 P/S advice on repair
The definition of this code is:
P1309 Engine Misfire Detection Monitor not enabled
It's a problem with the detection circuitry, not a detection of a engine misfire condition. I found this quickly on the net:
Diagnostic Trouble Code (DTC) P1309 indicates Misfire Detection Monitor is not enabled.
Breakout box installed, PCM disconnected. Connect digital multimeter between PCM test pin 85 and test pins 51 or 103. Bump engine in short burst with the starter without starting engine for at least 10 engine revolutions. Answer this question: Does digital multimeter reading switch between low (less than 2.0 volts DC) and high (greater than 8.0 volts DC)?
If Yes, Verify correct installation by referring to the Powertrain/Engine Group in the Workshop Manual. If the CMP is installed properly, REPLACE PCM. RESTORE vehicle. RERUN Quick Test.
If no, REPLACE CMP sensor. RESTORE vehicle. COMPLETE Misfire Monitor Repair Verification Drive Cycle. RERUN Quick Test.
The CMP sensor is the Camshaft Position Sensor.
Nov 08, 2010 | 2000 Ford Taurus
My alarm goes off randomly
Many alarms have a mercury tilt switch for motion detection, and if it is set too sensitively, a good gust of wind can set it off.
You need to adjust its sensitivity setting.
May 05, 2010 | 2000 Isuzu Rodeo
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
Computer won't power off
The most common reason for this problem is that ACPI (the Advanced Configuration and Power
Interface) isn't enabled. To enable it:
Click Start | Control Panel, select Performance and Maintenance.
Click the Power Options tab.
Select APM - Enable Advanced Power Management Support.
Click OK.
Dec 29, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Computers & Internet Logo
308 people viewed this question
Ekse
Marvin
Marvin
