My engine won't turn over
SOURCE: turn the switch off motor keeps running
It sounds like there is a short in the alternator or wiring for alternator. You are continuing running with the battery cut off. But the outboard generates its own power and its finding the way to the ignition. As for grounding, you may be idling too high for a quick shut off.
SOURCE: 1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
SOURCE: yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
SOURCE: 1989 galaxie boat. inboard/outboard 4.3l stiff steering
The first thing I would do is disconnect the steering at the transom. You want to find out if the problem is in the helm(steering wheel) or in the inboard/outboard pivots.
When you turn the wheel after the disconnect, it should not be hard. There is a set screw in the steering assembly either above or below the dash. There should be enough tension so the boat does not wander but not enough to be terrible to steer.
Next go to the outdrive. Without the steering connected, the outdrive should move with minimum resisitance in either direction. There are pivot points on top and bottom that should have marine grease at the start of each season.
You have a 21 year old boat. The driveshaft in the Inboard/Outboard should be greased every 2 to 3 seasons and the watertight bellows can be inspected at that time.
Now if the steering is even worse under power, you need to adjust the fin that drops down behind the prop. This part controls Torque steer so the outdrive is not trying to turn on you and wants to stay straight. If you do not have a problem leave it alone.
You can get an estimate for the driveshaft service and greasing U-joints and inspecting the bellows. They should grease the pivot points then too. I am told its about a 2 hour job. In my area its 60-70 an hour.
SOURCE: I have a mercury outboard 50hp engine that will not start
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
