I checked the resistance on the gas solenoid and measured 196 ohm's on each. oven is turned on but nothing happens
Was the control set to BAKE mode before you checked for voltage? J1-6 will only be energized if relay K7 on the main control is closed... Does the unit try a spark sequence when you try to bake, is there the "clunk" sound followed by three "tap-tap-tap," sounds of the electrode sparking at the bake tube?
SOURCE: JGBP79 Bake Ignitor not glowing, even after replacing
My next step would be to replace the two gas coils. They are located on top the gas valve. Disconnect the elect. leads, pull upward on coils. Replace w/newones. The difference is a primary and secondary, one has two elect. prongs and one has three. Note which one goes where when you remove them and install new ones in the opposite. These tell the gas valves when to activate and allow gas to flow to your igniter. When they malfunction, and they do, you wont have gas flowing.
SOURCE: Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
SOURCE: I have a Maytag model MER5775QAW free standing
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
SOURCE: Lower bake element on Maytag MER6772BAB not
Replace it. You can find the part on repairclinic.com
Turns out both the control board and the DSI went bad. just letting everyone know.
