A
Alvastone Allen Posted on Jul 15, 2016
How do I fix a locked fan on an optoma hd 25 lv
Optoma HD81-LV ... white lines on projected image
this has happened to many of these tvs, I would return it if you can, this isn't worth it to get fixed. I'm sorry if you can't return it, yours lasted less than many I have heard of
2answers
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Optoma 25hd air filter issues
Hi Cathy,
The replacement of the filter is something that needs to be done at a service center by a trained technician. If you are interested, feel free to send us a message: Projector Repair Bulb Replacement
I get the message of fan failure in my optoma hd 80 home theater projector, is it fixable, needs a replacement fan, etc.?
first vac and clean vents for proper air flow if still coding with unit unplugged remove cover and check fan for blockage if good and still fan code test fan, if bad fan is replaceable most electronics or some computer stores should have it if u want to diy can use serial&model number of projector or numbers on the fan
5helpful
Optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
Good luck!!
2helpful
3answers
Hey my optoma hd65 bulb blew so i replaced it and when i powered it back up i received the fan lock error
the lamp probably blew because the fan stopped. if the lamp can't cool down, it blows. you'll have to find out which fan and replace it.
Optoma h 27 will not power on at all. New lamp still not working.
Never heard of a heat reset. If the unit is completely dead. investigate lamp, and or lamp door interlock switch.
2answers
How to open mirage island?
There's a man in Pacifidlog Town in the house southeast of the Pokemon Center who will tell you if he can see Mirage Island. If he sees it, it's there. Take each and every one of your Pokemon to this man every single day until he sees Mirage Island. Then go splurge.
found in the big empty space on Route 131
Rt 130 Mirage Island
Wynaut Lv 5-50 Very Common
surf
Tentacool Lv 5-35 Very Common
Wingull Lv 10-30 Common
Pelipper Lv 25-30 Rare
fish
Old Rod
Magikarp Lv 5-10 Very Common
Tentacool Lv 5-10 Common
Good Rod
Magikarp Lv 10-30 Very Common
Tentacool Lv 10-30 Common
Wailmer Lv 10-30 Common
Super Rod
Sharpedo Lv 30-35 Common
Wailmer Lv 25-45 Very Common
Rt 131
surf
fish
Old Rod
Good Rod
Super Rod
Rt 132
surf
fish
Old Rod
Good Rod
Super Rod
Wailmer Lv 30-45 Very Common
Horsea Lv 25-30 Uncommon
Rt 133
surf
fish
Old Rod
Good Rod
Super Rod
Rt 134
surf
fish
Old Rod
Good Rod
Super Rod
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
