1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
SOURCE: Driver for HP Laserjet 6L Pro
sir i have lost the cd of printer driver which i got along with prienter now sir i want to get driver for my printer so how it is possible replay me.
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
SOURCE: how do i reset my hp laserjet printer 1320 to its
It may be a defective cartridge regardless of its age. Did you remember to remove the pull strip on the cartridge? Is it getting more faint as you print more? If yes, replace the cartridge.
SOURCE: how to reset the pages
Restore to factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name, phone number, speed dials, and any stored faxes in the product memory. CAUTION: This procedure also clears all fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. 1. On the product control panel, press the Setup button. 2. Use the arrows buttons to select the Service menu, and then press the OK button.
3. Use the arrows buttons to select the Restore Defaults
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Cold reset HP Laserjet M3027/3035
1. Turn off the device.
2. Turn on the device.
3. When the control-panel display shows that the device has begun to count the memory, press and
hold the 6 key.
4. When the LED lights turn on, release the 6 key.
5. Use the 3 and 9 keys to scroll through the options (select language, cold reset, embedded LAN
enable, and embedded LAN disable) and then press the 6 key to select the option you want.
The device continues the power-on sequence.
