Odd. Is it the newest programming cable? I had issues with the old one fitting the radio, but not writing to it. Try to get a model number on the cable. Also, download the latest software. If the radio was programmed with newer software than you have, it will often not program properly. Moto means to keep you updated even if you don't want to.
Your making a new file and programming was the exact correct thing to try. So, that is why I'm concentrating on "odd" issues. Best of luck! John
RDU4100 Two way Radio I hope you can locate some information you need Parker. If not, let us know. Have a blessed day. Thank you.
Testimonial: "No luck so far, I just created a new 4100 profile and tried writing that the radio with no luck. Do you have any suggestions."
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
