FS and LGL size paper4 gets jammed in Seperator section, before entering into fuser section . The copier is working fine on A4R size from Tray 1 and bypass tray
Then place the LGL and FS in tray one does it work??? is this printing or copying???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: paper jam behind first paper
Download this manual->X88BvEGG/KONICA_7020_7022_7025_7030_703.
Go to page #105-106 Disassembly/Assembly .
You will find all the instructions you need .
note:
PDF manuals require the Adobe Acrobat Reader for viewing and printing.
http://get.adobe.com/reader/
I have had a lot of jams because of a little torn paper is in the path of the paper. Need to follow the path. Removing paper just won't fix it. You may need a flash light and a pick sometimes and look in the area of the leading edge of the paper where it stops.
SOURCE: 350 Toshiba copier paper is stuck where is the problem
Need mush more information on this problem to assist in any way.
