Washing Machines Logo
H
Henrietta Boros Posted on Jul 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont start, no error codes, what could be the problem?
Anyone could help me with Hotpoint-Ariston AVTXF 149, i doesnt work, no error codes, all the lights flash, led display ok, but its automatically shut down, it wont start anything. Sorry for my english, its not really good.
David Ellis Rhea
Level 3:
  • Hotpoint-Ari... Master 3,462 Answers
  • Posted on Jul 11, 2016
David Ellis Rhea
Level 3:
Answers
3462
Questions
Helped
784859
Points
10903
I would check the lid switch.
These switches are normally made of plastic, and are made really cheaply, and break often.
When they break the washer will no longer start.
Have someone raise the lid and check it out.
God bless your efforts.
I have a Hotpoint-Ariston OS 992 D C IX/HA oven (model code: 03596540000). It's showing F53 error code. What does it mean?
you may have problem with oven door latch,you may want call a qualifiled tech to repair your range
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Avtxf 149 f-08
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
2answers
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
1helpful
2answers
2answers
Hotpoint Ariston FK 89EL.20 X/HA Electric Oven
Same error. No fix find yet. Only push on/off button 3 seconds.
1helpful
I have a Ariston Avtxf 149 that is locked down with f12 error mode.
F12 is a communication error.
The electronics aren't talking to each other properly.
F5 means the Pressure Switch jammed on full
Possible pump block, check pump etc. for blockage
Check pressure switch, wiring and module connections. Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages.
19helpful
4answers
14helpful
3answers
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Top Hotpoint-Ariston Washing Machines Experts
john h
Are you a Hotpoint-Ariston Washing Machine Expert? Answer questions, earn points and help others
