If I understand correctly, you are referring to a password that is set in the computer's BIOS which comes before the operating system (Windows / Mac / Linux) starts.
Most BIOS passwords can be reset using a jumper on the motherboard. This is where it gets very specific to the motherboard so you should look for documentation on your specific HP model at support.hp.com.
Typically, you move the CMOS jumper to different pins, power on the system and when the POST completes, turn it off, move the jumper back to its original position, and the computer should start without the "power on" password. In short, it removes whatever changes were made to the BIOS.
I hope this helps.
SOURCE: Forgotten password
I'm assuming you are not using the default "ADMINISTRATOR" account of windows. Try this if thats the case on the user name screen
It gives you the lon on screen
and you will be able to go on the desktop.Then you can remove the
password for your preferred accout.
From CONTROL PANEL>USER ACCOUNT. Select the account you wanna remove the password and Click on
Lemme know if that helps.
SOURCE: Somenon put a power on password on a hp desktop
Turn the unit off. If you open the unit there will be a jumper to clear the CMOS and a battery. Remove the battery and then switch the jumper as silkscreened on the board. usually there are 3 pins currently crossed are 1 and 2. switch it to 2 and 3, press the power button then hold for a few seconds. unpress the button and remove the pwoer cord. press and hold the power button again for a few seconds to clear all power. reconnect the jumper to 1 and 2. put battery in and plug and boot. password should be gone.
in some units there is a "clear password" or "cmos password" jumper. crossing this will remove the password in those units.
SOURCE: HP Compaq DC7900 PC Desktop power
please mention which operating system is being used or where you facing password problem????
SOURCE: How do I remove a password from my HP PC desktop?
In windows? Or on the computer itself? If it's a system admin password just go in to the bios and where it says administration and password go in and tell it not to ask anymore.
