Hi if you're tablet is in good condition u should B able to get all you're google apps if u open up a Google account & connect to the internet .good luck
is there an error message? make sure you are connected to WiFi then try to update the google services mannually.
Go to Settings > Security > unknown sources enabled it. This just allows you to install apps from outside Google Play. Google Play services 11 9 51 APK Download by Google LLC APKMirror
Make sure you download the Google Play Services APK from link, then install it. Your tablet must be Android 4.0 and above. how this helps. please reply.
That is the thing, to use any, and I mean any Google app on Android you must have Google Play Services install.There are a variety of Google Play Services that you could download and install, but since your device is not an known brand to the Google Play Services, you need to download each version and try it, until you get the right one. If you go to the link, you'll notice that it says "All Versions". When you read the version number, the last three numbers is the code to the device it is compatible with; example: the version that ends in 438, this version is compatible with Nexus 5. Here is the link to download Google Play Services. Make sure that Unknown Sources is enable within Settings>Security.
Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
1. Remove the updates for your Google Play
- Go to the menu->settings->apps->all->google play store-> uninstall updates, then reboot your device.
2. Remove the cache for your Google Play
- Go to the menu->settings->apps->all->google play store-> remove cache, then try to run your google play again. It is better to do a reboot.
3. Try to delete and re-install Google Play
- In some cases, delete and re-install resolve this issue.
4. Try to delete your google account and add your google account again
- Go to the menu -> settings -> account remove your current google account then add it again here.
Find out what the operating system is for the tablet.it doesn't sound like android , more likely Linux or even Apple Mac or Microsoft.if it was android then it would accept some version of google play.
