All Nokias has a unique configuration process which can be found within the setting sub manu. simply go to your phone manu, select setting, select connectivity, and open pocket data options. under pocket data section, select "always available" and within the same section, choose the ISP (Internet Service Provider) network and/or GSM network you are subscribed to. If this doesn`t work, contact your GSM and/or Internet Service Provider for additonal help.
SOURCE: My new unlocked nokia 6288 cannot connect to gprs
to connect to the internet or set up email or to send mms you must activate the GPRS first from your
network provider ...The best thing you can do is to contact the
customer care of your network provider and ask for the activation of
GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you
will receive the gprs settings(profile) also ... make sure of the
charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if
the customer people tell you that your handset is not compatible for
the receiving of the profile settings then you must tell them to give
the manual settings(includes ip address,APN,etc) so that you can only
create the profile and input the information given by the customer care
people...
if you have already subscribed the GPRS then call the customer care of
your network provider & ask for the settings by telling your model
of the handset ..
any further doubts reply me
i am always here to assist you ..
thank you
bye...
rate my solution
SOURCE: mobile phone - invalid web address
Download opera mini that is compatible with your device from www.getjar.com. Try connecting to the web using your opera mini browser.
This should reso;lve your problem.
Regards'
SOURCE: when i open the web
Hi, i solved your problen.Take your phone and go to manu>settings>configuration>personal configuration settings>and press options>add new>web , and creat a new settings and set to active..Or, contact service providers..
SOURCE: How do I fix an invalid web setting for a nokia
Request new configuration from the service provider.Thanks for visiting fixya
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 2690 Flash File and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
