First, see if you get the same result when you run the machine on "Air-Fluff." If you don't pop the breaker on Air -Fluff you know the problem is originating in the heat circuit, get inside the machine and inspect the wiring for crispy/burned terminals and the heat element for damage or contact with the housing... If it does pop the breaker on Air-Fluff: Inspect the terminal block on the back of the unit where the power cord is bolted on (with the unit unplugged), look for any scorched spots- if that is clear, remove the outlet cover and inspect the wire connections on it for scorching (with the circuit break off). Can't be more specific without a model #!
Help Me Find My Model Number RepairClinic com
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
SOURCE: Kenmore 80 series dryer won't start
Look for a bad thermal fuse pix below.Straight wire to test it.Replace if the dryer turns on. 2nd. Test the door switch.
Please rate This !
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
The
Kenmore 80 Series of dryers are consumer grade dryers for home use. As
with most home appliances, the Kenmore 80 series dryers will
occasionally not work as intended. If a problem occurs with your dryer,
however, you do not necessarily need it serviced by a technician. You
can attempt to troubleshoot and fix any problems with your dryer before
contacting a technician.
