Samsung MULTISYSTEM LED TV UA467000 - 3D LED TV FOR 110-220 VOLTS Logo
A
Anonymous Posted on Jul 03, 2016
My LED TV on powering up the screen (Samsung smart TV) flashes continuously.
Is it power supply board problem or could be other part ?
Level 3:
  • Samsung Master 19,187 Answers
  • Posted on Jul 09, 2016
Samsung Master
Level 3:
Answers
19187
Questions
0
Helped
4345259
Points
82261
1helpful
GREAT PICTURE AND SOUND BUT ABOUT 6" UP ACROSS THE BOTTOM OF THE SCREEN IS DARKER THAN THE REST OF THE SCREEN. HOW DO I DETERMINE IF ITS A BAD STRIP OF LEDS OR THE LED BOARD??
Inmost of the case,the problem is the LED strips.
To check it, the best way is use a LED tester, if you do not have one, you have to disassembly the LCD panel, unplug the cable between the power supply & the main board, apply the AC power to the TV, you will see the defective strips do not light up.
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Samsung smart tv has a black screen that flashes to a real screen for about 1 second then goes back to black. it has sound
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
4answers
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Top Samsung Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
