SOURCE: Baumatic BHD5 works then buttons start flashing and it beeps and stops working
Before buying a new control unit, try to unplug the machine for few hours and plug it back in. It might reset the control panel and solve your problem. Good luck!
SOURCE: Hotpoint aquarius dishwasher, After 2 minutes
its not on the door.
it will be inside the washer.
once you pull out you can see the power board manually with sharp eyes.
there look for elements that are puffed on TOP.
just go and replace them.
SOURCE: My AEG 18 in. Favorit 54750Vi has stopped working.
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
