How i can detach/unscrew D-Link Dir-600M Broadband Wireless Router external antenna to replace with new external antenna?.
SOURCE: DIR-655 Connection Support
Don't worry about it, The router is backward compatible to B,G and N only. the Router that your is wireless extreme N. Some of the A, D is not been supported by the router that means that we are on a new generation, there some older router can support the A,D.
SOURCE: How can I extend the range of my D-Link DIR-655
You bet.
Please see the link below for an example.
http://www.pricebat.ca/D-Link-WL-DWL-G710-Wireless-Range-Extender-802-11g-54Mbps.p_10022985/
SOURCE: Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Testimonial: "There was a problem with router itself, after replacement everything works fine. Thank you for an advice"
SOURCE: Hi I cant configure my router D-link DIR-300
This definitely worked for me. To find out your computer's MAC address, just go to start, then click run, then type 'CMD'. When prompted, type 'ipconfig/all'. Find your ethernet adapter local area network connection, and underneath you will find a lablel titled Physical Address. This is your MAC address and should consist of 6 pairs of number/letter combinations. Then connect your computer to the modem, eithe wirelessly or directly and point your browser to 192.168.0.1. Under Setup click Internet Setup and then click Manual Internet Connection Setup. Under Internet Connection Type, select Dynamic IP (DHCP), then under MAC address, type in the MAC address of your computer. Click Save Settings and Presto! It worked for me.
SOURCE: how to remove antenna off a d-link dir-615
In D-link router you can see a special notch like Indicom hand set or some fixed antena if this is a fixed then you have to open the case of router. But It will violate tyhe guarantee. But anywy just open the case and the back sid eyou can see the base area of thge antena with all attachment with cable. Carefully unplug all this.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
