My Pentax water pump does not cut off. Can i install a mart head on it what it runs without stopping
SOURCE: water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
SOURCE: water pump constantly running on Carrier gas furnace
Yes I agree with Master_tech Be sure the shipping retainer was removed if its a new unit, if its an old unit clean it and put an algae tablet in it.
SOURCE: washer not draining all the way
OK, so I had no luck finding any information on the WSXH208A. I knew this problem was possibly related to a clogged filter because of the responses related to other machines, but where the heck is the filter on this model...not easily found. Finally, after some persistence, I found it. The filter is inside the black rubber piece that attaches the drum to the pump. It is a small clear plastice piece with holes in it located inside the black rubber piece. Detach the black rubber piece from it's 3 connections...1 to the bottom of the drum (unscrew the tightening screw at the top metal wire to loosen the connection), 1 connection to the pump and one other connection coming from the top somewher (both of these are connected with press-grip clasp type things). Take the entire black rubber piece out (make sure to have plenty of towels layed out and a pan to catch the water if you can. My pan didn't catch much, but the towels soaked it up anyway. Pull the filter out from inside the black rubber piece once disconnected. I actually had a dollar bill wrapped around the inside of my filter, completely blocking it. Once the filter is cleared, put everything back together. Make sure all connections are on tight to prevent any leaks. Hope this works for you...I was happy to fix it myself and avoid the costly repair-man!
SOURCE: 2000 HYUNDAI ACCENT STOPS RUNNING
Hi had a similar problem last week with my 2000 accent took car to dealer who put it on the computer, turned out that the 'mass airflow unit' needed replacing. Very expensive part cost £182 and labour £36 (Hyundai dealer) sorry!!!!
SOURCE: coolant leaking replace every three days coolant fan wont stop ru
This link has a diagram showing the location of the relay: http://autorepair.about.com/library/faqs/bl581g.htm
The Pulse Width Modulated (PWM) radiator cooling fan relay is located behind the front bumper fascia below the right head lamp.
