SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
SOURCE: i'm having an error on
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
SOURCE: error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
SOURCE: Sir i have printer machine KYOCERA FS-1118MFP.Now
delete the driver and reinstall it ... and check the connection also ....
if you want to download the driver goes through the below link
http://www.kyoceramita.eu/index/service/dlc.false.driver.FS1118MFP._.EN.html
if you facing same please describe your problem fully ......
The problem is the pin contact of RAM module. You need to retire it and place it again. If fails try to update without the RAM module, and try the same RAM or if not working try a new RAM module. My problem was solved with this method (updating without RAM and after this with the same RAM installed). Firmware inhttps://t.me/kyoceraFS1118MFP
