Motorola Mobility H710 Bluetooth Headset Logo
Thomas Tan Posted on Jun 25, 2016
Why I can't charge my Blueant V1? Tried all sorts of chargers and sockets with no help, very frustrating
2helpful
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
1helpful
Low battery and not charging
Hey Patricio,
Do you have another charger you could attempt to charge it with. If it is not charging I would suggest locating a copy of your reciept to confirm you are under 2 years and calling BlueAnt at 1 866 891 3032 for a warranty.
Rylan
It blueant v1 working with iphone 3g ?
They are fully compatible, although the Iphone 3G does not support voice dialing so you would only be able to make outbound calls to through speed dial (favorites on Iphone)
Rylan
The battery will not take a charge. When plugged into the charger, nothing happens, no lights, no charge. I also tried another charger with the same result. Can the battery be replaced? any other...
The battery is sodered into the unit, I would locate your reciept to see if you are under blueant's 2 year warranty. If you are call 866 891 3032.
Rylan
I jsut go a replacement blueant v1-x. I have a few times where the headset shuts off in the middle of a call and it reverts back to the handset. The battery is fully charged. thanks
I would test the device on another model of phone to see if the issue carries across, that will allow you to isolate the source of the issue at hand.
Rylan
Cannot connec the Blueant V1 device to PC (tried 3
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
I just got a Blueant v1 when connected I cannot adjust the volume, if I look on my Blackberry curve 8330 it is locked a half, all my settings are at 100% been looking around, but ain't finding nothing. If...
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
How do you answer an incoming call while on a call?
HI,
Please click on the below link to view the user manual for your model.You will find all the solutions to your problems in that:
http://www.blueantwireless.com/resources/V1%20Voice%20Control/V1_manual_update_V6a.pdf
Blueant v1 headset
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
