Garden Logo
George Ables Posted on Jun 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
John deere 332e skid steer loader
Hydraulic fluid temp is getting over 185 degrees and machine only has 100 hours on it
Dennis Key
Level 3:
  • John Deere Master 2,481 Answers
  • Posted on Jun 24, 2016
Dennis Key
John Deere Master
Level 3:
Answers
2481
Questions
Helped
749767
Points
6126
I would change hyd. fllter. Clean the hyd. screen
5 Related Answers
Anonymous
  • 463 Answers
  • Posted on Mar 26, 2009
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
jimmy nutron
jimmy nutron
  • 132 Answers
  • Posted on Jun 04, 2009
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Anonymous
  • 110 Answers
  • Posted on Jul 02, 2009
SOURCE: I just purchased a 2440 john deere tractor it was
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
A Miller
  • 8404 Answers
  • Posted on Sep 25, 2009
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
wfservices
Wayne Fellows
  • 262 Answers
  • Posted on Apr 07, 2010
SOURCE: i need to rebuild a hydraulic cylinder on a john
  1. This cylinder is not to hard to disassemble.
  2. Place upright in vise or suitable bracing.
  3. Using a block or dowel of wood(maybe rubber mallet also), depress the top cap of the cylinder to relieve tension on the ring.
  4. Use a small edged screw driver or pick and spin "retainer" in until the bent end comes to the opening.
  5. Lift up and rotate the ring more to allow the ring to pass over the edge of the opening.
  6. Once the retainer is started you can tap it with the wood and rubber mallet around the circumference of the cylinder to release the retainer from the groove.
  7. If you havent done so by now the oil should be drained.
  8. with the cylinder firm in vise(but not too firm to "distort the integrity of the cylinder.) Place the cylinder Sideways so you can pull out piston and rod assembly.*** Put hose or suitable drain on holes of cylinder***. With the motion of the piston the residual oil will tend to spray out.
  9. Pull on the piston and position it to bottom out on the top gland(cap) ie:full extension
  10. Place support under the rod to avoid damage. The gland is a tight tolerant fit with use of O-rings and backup rings. Too much offset can lead to damaging gland assembly, and jamming in the cylinder. You may be able to just hold with hand also depends on size, bore, stroke, pressure rating. Use due dilligence.
  11. Now that its out you have the piston assembly with gland in hand..**if only the rod comes out there are more steps to take, and you need a new rod but sometimes its more cost effective to buy a new cylinder. If there is a farm supplier or hydraulic dealer near they can certifiably /replace repair the cylinder for you. Hydraulic pressure is kind of like lightening. If it strikes you under pressure it can kill you.*** Using the dead blow or rubber mallet try to pop the gland out by using the piston/rod assembly as the puller. You may not have to remove the top clevice or other end of the cylinder, so maybe you could tap on that.
  12. The piston can be removed from the rod depending again on make. Usually a socket head cap screw or king nut holding it in place to the rod.
  13. When the piston is removed you should be able to slide gland off also.
  14. You'll need that pick and or the screwdriver to pick out the seals carefully. Let me know if you require more...WF Services
John Deere 320 Skidsteer hydraulic lock up for boom and bucket. Code F9H9.
We don't really deal with heavy machinery here. Either ask over at www.justanswer.com or get yourself a service manual for it. Unfortunately John Deere charge for them, but they are very detailed.
https://www.google.com/search?q=john+deere+320+skid+steer+service+manual+pdf
1helpful
2answers
I have a John Deere 5103 the hydraulics are jerky started out a little now its bad loader steering etc. Is it the pump or filters
indicates inconsistent pressure
low fluid level in reservoir, blocked filters or faulty valve system can cause the problem
My john deere 4200 hst tractor quit moving,power steering quit,frt loader quit all at once fluid level is ok
hydraulic pump problem
check drive connection to the pump
check input line to the pump has no air leaks and sucking air
Is it a big job to replace the brakes on a john Deere 250 skid steer
check with the service dealer
most skid steer loaders do not have brakes in the normal sense but have valves that lock the hydraulic fluid in the drive motors and so prevent them from turning making them brakes
What hydro fluid does a john deere 333d skid steer use
333D uses a variety of oil for the hydraulic system. Primarily 10W-30 Torq-Guard Supreme or 10W-30 Plus 50 II
EXCEPT: If your machine was equipped with the cold start package, it will use either Plus 50 II 0W-40 or Hydrau XR (Hydrau XR can be added to Plus 50 II 0W-40 in any ratio, ie. topping off 0W-40 with Hydrau XR is okay)
When releasing the park brake on my john deer skid steer the mofor dies
Pull the plug on this one as there is an electrical unit that is being affected by water. Have the washer checked out by an electrician and do not use it until it is declared safe.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
