Question about Invacare Health & Beauty
Invacare pronto 8 flashes, shuts off... The higher the speed setting, the quicker it shuts down and flashes 8 times. Do I need a new controller module or ? Thanks
  • 280 Answers
A flash code of 8 indicates a faulty controller
Posted on Jun 27, 2016
6ya staff
SOURCE:
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Posted on Sep 30, 2008
lennieg2000
  • 692 Answers
SOURCE: invacare pronto m51 moving very
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Posted on Aug 17, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: How do i know when my invacare pronto m5 is fully
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Posted on Oct 24, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: i have invacare pronto m51 with surestep the spjis
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Posted on Nov 20, 2010
Hello! I have a M51 Invacare Pronto that is not working. When I turn it on, the service light flashes eight times, one red battery light flashes as well, but nothing happens when I move the joystick.
If it flashes 7 green and one red for the 8 total then it's a joystick error. If it's 8 green and one red then it is a control/brain error code. Measure voltage on batteries when turn chair on. Both batteries need to stay above 11.5 volts each.
Jan 21, 2018 | Invacare Health & Beauty
Invacare Pronto M51 lights on controller blink 2 green 1 red
It means the battery voltage has dropped below the operating range of the chair electronics. Either need new batteries or maybe a charger and new batteries. There is always a chance of loose battery harness connections.
Jan 12, 2018 | Invacare Health & Beauty
What does eight flashes of the wrench indicator mean on the invacare Pronto m 41 power chair
A flash code of 8 indicates a computer controller problem. Check all the connections at the controller under the rear cover. A rebuild or replacement of the controller is probably necessary. Hope this helps.
Jun 10, 2016 | Invacare Health & Beauty
How do I reprogram my invacare pronto m51power chair
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
May 02, 2015 | Invacare Pronto M51 Power Wheelchair
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
Oct 16, 2014 | Invacare Pronto M61 with SureStep Rehab...
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
Jul 08, 2014 | Invacare Supply Group Invacare Pronto M91...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Speed control knob has come off
you need Invacare part # 1040225, cost about $6.00. Call these people 866-722-4581
Sep 21, 2009 | Invacare Pronto M51 Power Wheelchair
Wheelchair problem
sounds like you might have locked joystick by mistake. Try pressing and holding down the on/off switch for 5 seconds.
Jun 14, 2009 | Invacare Supply Group Invacare Pronto M51...
Health & Beauty Logo
580 people viewed this question
Top Invacare Health & Beauty Experts
Rob Hill
Rob Hill
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
