Question about Peavey Music
Peavey mixer model xr8600. - Peavey Music
    Top Expert:
  • Peavey Master
  • 12,962 Answers
Question?
Posted on Jun 22, 2016
6ya staff
SOURCE:
L want to need circust for peavey xr8600.
You should contact Ppeavey customer service. Here's the link-
Peavey com
Jan 09, 2016 | Peavey Music
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Sep 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My husband purchased one of your xr8600 peavey mixer the problem hes having is he cant get the echo settings right.please can you help.
View videos on YouTube regarding "mixer setup". Find the parts of setting up of "effects". Don't worry that you have a different mixer, the principles are all the same for analog mixers. Steps are this: Set the EFX send level for EACH of the input channels (knob above each channel gain) for the proportion you want for each channel. Check that the level you are sending does NOT cause the effect clip light to light very much. Set the effect you want, delay, echo, etc. with the selector knob. Advance the output sent to the power amp with the two knobs in the upper right of the panel. Adjust the "time" knob for the delay or effect depth you want. Then go over the same settings in the same order until you get the sound you want.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Trying to find the mute j111 on xr684f
I don't believe there is a mute function on the XR684F unit. There is a mute on the XR8600 but they probably use different boards in it. The mute button for the XR8300 and XR8600 are near the effects selector button and LIKELY is board mounted and would not have a J111 connector. If the electrical function is in the XR684, it MAY just be pads like test points, to only be used during testing and troubleshooting.
Mar 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have an XR8600 - I am using it without Monitors. The Main/Monitor Send is sending a stonger signal to one speaker than the Main/Main send is to the other. have checked leads and speakers and know it has...
Check the pan cotrols are at 12 o;clock.
Verify your speakers are identical and speaker cord length is about the same.
Swap speakers to make sure it is not the speaker,
Feb 17, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Music Logo
44 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
