Locked by icloud but acct no longer exsist
Sometimes people rename apple id and old one still shows up in icloud settings of the phone.
1. 98 % of those resolved by using correct current password for new account to sign out.
2. 1% of the rest resolved by having to reset password during sign out process directly on the phone using security questions (needs to be done during sign out when old password is not accepted).
3. The rest have to go to icloud.com and remove phone from icloud first. Then check at icloud.com/activationlock if device is unlocked and then restore the phone in recovery mode. In order to remove it device has to be offline.
Notice all that only works if account does not exist anymore, cause it was renamed.
SOURCE: How can I unlock iCloud?
Hi Malibu , If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
Hi Turn Burn, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? In addition, please confirm your Apple ID is not locked by going to appleid.apple.com
