Whirlpool WTW6400SW Cabrio Washer Logo
N
NICKI CRIBBS Posted on Jun 22, 2016
I cleaned my washer with affresh and it still smells very sour
I got this washer from my mom and it did not smell when i got it a couple of months ago. i have tried affresh and it only lasted a short time and now it smells really sour again. i tried leaving the lid open between washes and it doesn't make any difference
5 Related Answers
Anonymous
  • Posted on Jan 11, 2008
SOURCE: Sour Smell in clothes
I had this same problem as everyone (especially with a front load washer) has. After research... I have found a product that I now tell everyone about. I found it on the web called 'smellywasher.com'. A nontoxic product by Laundry Specialist sounded good. I was willing to do anything to cleanup the smell and mildew from my machine. So I gave this a try and it REALLY WORKS!. Just as they claimed, my washer now smells clean and with no real effort from me. Now I just do a periodic cleaning and I will never have to worry about this again. (and bleach will harm the gaskets). I also use vinegar in the fabric softner dispenser instead... this insures my clothes are rinsed well and works to soften my laundry. Hope this helps and pass the info on..... THIS REALLY WORKS....which you cannot always say about products.
A
Anonymous
  • Posted on Sep 20, 2008
SOURCE: smell, mold , and mildew
Do you always leave the washer open? We've never had this problem but they told us to always leave the door open slightly whenever it's not running.
Anonymous
  • Posted on Jan 13, 2009
SOURCE: towels smell oily and moldy--really stink
Don't use fabric softener. I had the same problem and read somewhere to stop using the fabric softeners. I don't know why but after about two cycles (they smelled really bad) it worked! I always used fabric softeners with out a problem but one day I just started getting REALLY smelly towels. I always take my wet wash out as soon as the cycle ends and dry it completely so I was surprised when they smalled so bad. Give it a try.
Sergio Vicente
  • 84 Answers
  • Posted on Feb 06, 2010
SOURCE: clean the washer using the AFFRESH wipe down
the smell comes from the fabric softener people use,put the machine through a hot water cycle and use CLR in the detergent dish,and after your done the wash always leave your door open on your front load so it can get air
Anonymous
  • 116 Answers
  • Posted on Jul 26, 2010
SOURCE: I have a front loader that smells like something
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
1helpful
2answers
Why does my front loading washing machine smell bad and make my laundry smell sour?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Everytime we do laundry, we have a horrible smell in the washing machine. We have tried bleach and hot water but no success. Any other ideas?
Be sure your using HE Laundry det. only use the recommended amount on the bottle, I use the liquid, the less the better, I use the least amount.....To much soap left in clothes can cause mildew and stinky smell, also I recommend using a fabric softner, it helps to remove the soap....and smells good....also use a good washer cleaner, I use Affresh, they come in tablets, go to www.affresh.com and put in you zipcode to find where you can purchase it in you area......make sure after a load is finished that it doesn't sit in the tub with the lid down for long, removing the laundry promptly will also help with stinky laundry........also, leave the lid or door open for a couple of days to air it out after cleaning.....use the Affresh at least once a month.......hope this helps you
After washing with my whirpool duet my wash smells sour. Any idea?
Try using Affresh washer tablets. This kills the smell in front load washer. You can order this online or at a local parts store. Works great. I use it on all the front load washers that i sell in my store.
2answers
The machine smells moldy even after I ran clorox through it.
keep doing it. it is going to take more than one cycle of cleaning to get rid of the smell. They sell products to help clean out odors of washers. These are some products you can use Washer Magic or Affresh tablets. If you have a Sears near you they sell it. I would use hot water and bleach one cycle then do a Affresh tablet. See how it goes
I have a Whirlpool Gold Ultimate Care II, Commericial Quality, Super Capacity Plus...it smells. No really it has a terrible odor. It's a sour foul smell. Water and detergent and various clothes washing...
Whirlpool now has cleaning tablets to take the smell out washers. They say they are for HE front load machine but it works on all machines. They are called affresh washer tablets. Just buy some and put all three tablets in the tub with hot water and let the washer go through a cycle with just the tablet(no clothes). By putting all three in the washer at one time it will kill the smell. For later use the package is a three month supply. They cost under 10 dollars.
1helpful
2answers
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to...
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
1helpful
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
3answers
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
