Drill slider to change gears between 1 and 2 is not sliding into 1. It is locked into 2. When forced it will move most of the way towards it but does not actually change to 1st (low speed). All other functions work correctly and the drill sounds healthy when used in 2nd (high speed).
Gearshaft problem with the gear house
a border of small ridges which must be locked in first gear, the gear shaft that runs now through if engine is running and switch from 2 to 1 gear , the locking teeth becomes broken in the housing
126410-4 is the ordering but no separate parts to get "Do not run the machine if you switch from 2 to 1 or 1 to 2 there are 2 special springs inside the switch slide inside to switch the machine having to rotate because inside the metal (aluminium gear shaft ) that Vertaling voor is scherp getand en maakt de plastic borging kapotVertaal in plaats daarvan naar is scherp getand en maalt de plastic borging kapot is sharp serrated and makes the plastic retainer broken.
