WHAT IS error 4202 : 0006328 on the Kyocera Ecosys FS-C51510DN
I don't have a maintenance contract and want to know what it would cost to get it repaired with this error - error 4202 : 0006328 on the Kyocera Ecosys FS-C51510DN
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
Be sure to power down and disconnect the power first.
A fuse it is blown within the fuser unit - replace that fuse or call a technician to do it for you.
for kyocera 1820LA look if it's works: turn on your computer by opening the top door previously. you press the menu system. you fit in service configuration and enter. press the START and # then enter. done this in configuration service runs a new submenu called maintenance mode. until it happens you should try this. when you enter maintenance mode out and then back. browser to locate yourself U163 code. you give execute.
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
