1. Try resetting the router. You will have to set it back up after.
2. Update any firmware - go to Belkin's site, or there may be an option in the router's control page/application to check for and apply any updates.
3. The router itself may just be going bad and need replacing. It happens after a while.
SOURCE: belkin f5d7132uk keeps disconnecting
have you tried turning off Wireless Zero Configuration
Go to Start | Control Panel | Administrative Tools | Services
Scroll down to Wireless Zero Configuration, right clicking properties, and Stopping the service in Service Status.
Do this on all the Pcs,
If this solves the problem, turn off Wireless Zero Configuration permanently by changing Startup type to Disabled
SOURCE: why does my belkin g wireless modem router f5d7634
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
SOURCE: belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
SOURCE: My belkin N router flashes amber on my modem...all the time.
You may need to upgrade the firmware of the device. Please see setp by step instructions here: http://en-us-support.belkin.com/app/answers/detail/a_id/497/q/routers
Download your latest firmware from: http://en-us-support.belkin.com/app/answers/detail/a_id/306/kw/F5D8236-4/r_id/166
SOURCE: Belkin N router keeps disconnecting
Try setting the router to another channel, like 11. Default channel settings often conflict with cordless phone channels, yours or your neighbors.
