SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
SOURCE: replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
SOURCE: I have a hayward s200 sand filter. When I vacuum,
Are you using the rinse setting for a few seconds following the backwash? If not, once you finish washing, stop the pump, change the valce to rinse, then run it about 3 to 5 seconds. Shut down then switch to filter and the particles should stop coming back to the pool.
SOURCE: Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
SOURCE: my cousin has the hayward sp714 filter. she lost
Instructions are on side of filter tank.Looks like a pro series top mount. Turn pump off.Press down valve handle and turn to backwash. Start pump. When water runs clear , rinse and return to filter. The pressure gauge is defective! Replace. Superchlorinate pool.
