SOURCE: manual
Seagate.com. Try these links out
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/ps3200_users_guide.pdf
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/quick_start_cards/ps3200_quick_start_quide.pdf
http://www.seagate.com/ww/v/index.jsp?locale=en-US&vgnextoid=45f3004f9f650110VgnVCM100000f5ee0a0aRCRD&vgnextchannel=dbe13d317972b010VgnVCM100000dd04090aRCRD
SOURCE: how can i install the maxtor personal storage
You do not need any driver. This device is plug and play in Windows XP. If it doesn't work then you probably have a USB problem. Have you checked in Device Manager to insure the usb port is working properly and is compatible with the drive, eg: usb 2.0 or usb 1.1?
for any further information refer to this link :
http://forums.driverguide.com/showthread.php?t=19966
Thanks,
Prince
SOURCE: Maxtor 3200
There is a troubleshooter that describes steps for these symptoms on Seagates Knowledge Base website.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=188697
SOURCE: I have a Maxtor Personal Storage and I am
I think that your USB driver in your WindowsXP is corrupted, what u can do now is to uninstall and reinstall the USB driver. But 1st please make sure your XP must be Service Pack 1 or above.
1) Goto Devices Manager, it is located in Start>Control Panel>System>Hardware tab>Device Manager.
2) Expand the Universal Serial Bus controllers, uninstall all the USB Root Hub seen from the list.
3) Restart the computer and then plug in your USB devices then let the WindowsXP auto reinstall the USB for u.
If this not solved your problem, then try to install the USB driver from website (availability 2009Oct06): http://www.viaarena.com/Driver/VIA_USB2_V270p1-L-M.zip
or u can google it.
Another possibility is your device maybe spool so windows cannot recognise it, what u can do is try to plug your device in other PC and see whether it is recognised by the PC or not.
YBC (/)
SOURCE: i need driver for Windows Vista
Hi i cannot find the driver either , but what you can try is Download XP drivers for it , then right click and run in compatibility Mode for XP , and it should install
