Washing Machines Logo
Posted on Jul 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Topload maytag washer partially fills by its self overnight or even a day or two may pass.
Anonymous
Level 3:
  • Master 525 Answers
  • Posted on Jul 18, 2009
Anonymous
Master
Level 3:
Answers
525
Questions
Helped
270827
Points
1508
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Your washer has a defective water inlet valve.
The link below is courtesy of. www.repairclinic.com,
They also provide repair parts, disassembly diagams and procedures.
http://www.repairclinic.com/SSPartDetail.aspx?s=b4a11i868761&PartID=868761
This may not be the exact part for your washer.
You will need the complete model number from the product ID tag which is affixed to your washer, to obtain the correct part.
TIP:
If it is convenient, it is advisable to turn your washer faucets off when not in use, to prevent accidental flooding
Washer fills overnight (GHW9400PW4)
a bad water inlet valve try unplugging machine and see if it still does it? if it doesnt do it when unplugged then u have an electrical signal problem from eiither control board or timer if it keeps doing it when unplugged its ur water inlet valve
2answers
I have a Maytag Topload Washer Moderl PAVT2448WW
it may need to replace the MAIN DRIVE BELT , before assuming it could be the motor, HOPE THIS HELPS , AJ
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Washer will not spin
Sounds like it could either be an electrical problem, with the signal from the timer control board getting to the gear box,,, or it could be the gearbox itself.
GE topload washer occasional screeching noise during wash cycle
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
2answers
Soap residue
if you just have a soapy residue( bubles atop the clthing?? either your using way to much soap, or way to much of wrong soap.you need to use HE detergent specifically formulated for front loading amchins(low sudsing. or your having a cold water inlet problem set te hunit to cold/cold/ try running see if inded the machine fills
Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
Washer won't fill
First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
1helpful
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
