I-INC UniK Trio AXS 3G with Wifi 7.85" Touchscreen Quad Core Tablet Mach Speed 1.2 GHZ 16GB 2014 Release T-Mobile 3G Slim Folio Case [Bonus Stylus] - Hot Pink Logo
A
A MOOR Posted on Jun 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tablet wifi will not turn on i already try to hard reset it
Thank you for all the help
Brett Duxbury
Level 3:
  • I-INC Master 4,352 Answers
  • Posted on Jun 15, 2016
Brett Duxbury
I-INC Master
Level 3:
Answers
4352
Questions
0
Helped
1119190
Points
13423
Has it got an aeroplane mode in the settings that might be on ?
or a manual switch that might put it in aeroplane mode.
Asus tablet Zenpad10: after factory reset Setup Wizard is crashing
Try holding the power button and the volume up button same time when hear a vibrate realise them both
2answers
How do i get my wifi internet back
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
3answers
To many pattern attempt
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
To many patten attempts
My screen froze
remove the battery for 10 seconds and reinstall again
Shutting itself down
Make sure the charger is plugged in before attempting this. If already plugged in or same thing happens then you can try and follow the guide as below to do a hard reset:
http://www.mobicpc.com/how-to-hard-reset-archos-97-titanium-hd-to-factory-default-setting.html
If still not able to reset, poss hardware issue
Thanks
2helpful
How to unlock HUAWEI s7-931w tablet
If your having problem like this I suggest that you perform a hard reset. To hard reset just simply follow this step.
And remember reseting can delete your all access data specialy passwords and code.
To hard reset:
1. Turn off the whole system.
2.Hold together buttons: Power + Volume Down. In several second until logo appear on the screen.
3. Release the buttons. And without asking and without notice System will automaticaly doing a reset.
If this will not succesfull, try to create google account on PC. Then remember all information you've made, the email and password. You said system asking you to sign in to google. Use all information you've got to sign in.
Note: The google method is not working on other tablet, but most of it solve the problem. Then you should go to area where you have an a access of wifi, place where can you connect a wifi. Internet connection is realy realy needed.
Hope it will help.
Top I-INC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an I-INC Tablet and eReader Expert? Answer questions, earn points and help others
