SOURCE: Kenmore 60 series will not spin or agitate
Common problem with these top loading Kenmore models.There are many step by step solutions on replacing whats called the motor coupling(3 pieces) An easy way to tell if this is your problem when you pull the washer out you may see a pile of black(or maybe even white) shavings right under the motor.The coupler keeps you from doing damage to the gearbox and breaks away first.It's a pretty easy repair if you follow the step by step instructions found on this site.(sorry I don't know how to linc for you) I just read a bunch of them and even found a couple that were on youtube showing video.The part is readily available on line or in my case at an appliance repair shop close to me.The hardest part of this repair for me was just getting the cover off first,but once again there are step by step instructions for that on here as well.The part is about 13-17 dollars,and it is a little tricky getting the one end on the gearbox,but take your time and follow the help full guides and it really isn't that bad.The cause for this problem seems to be first of all the material that the part is made of,but is mostly caused(from what i have been reading) is overlaoding of your washer.
Hope this helps,doing this repair is a whole lot cheaper than calling Sears
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
