SOURCE: need to buy parts
Per the Manual I received with my vacuum.... try e-mailing [email protected]
SOURCE: Bissell easy vac plus
Press the lock button down and forward (away from the
Canister Handle) while lifting the upper portion of the Dirt Cup
away from the Canister. The bottom box should then come out.
If you need a user manual for this model I have one and can send it to you if you email me.
SOURCE: Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The Durabrand filter can be found at http://www.totalvac.com/accessory/parts/H19030.html
SOURCE: I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
