Whirlpool LER4634J Electric Dryer Logo
Posted on Jul 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT YESTERDAY TODAY NO HEAT BREAKERS ARE FINE
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Jul 17, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1510941
Points
12435
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
Dryer worked great yesterday , today no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
4answers
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Will not heat
Check your house fuse/circuit breaker panel. The dryer runs off 2 circuits -one for heat and one for the motor.
Mar 14, 2010 • Dryers
3helpful
2answers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
1helpful
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Dryer won't dry
Without a meter there is not much you can do but a couple things to try , 1st turn the breaker off , when turning it back on push the breaker switch firmly in toward the panel then check for heat . the breaker may be running only half power and not supplying the heater [bad breaker] , the next thing is the temp. fuse on the heating element case. take the ;arge back panel off of the unit , you should see the element case on the right , it should have 4-6 red wires going to it , the fuse is located at the top of the case , remove the 2 red wires from it and slide them together then use electrical tape to tape them carefully power unit back up and test for heat , if it is working now you most likely have an exhaust problem , check the airflow where unit exhaust. let me know if you have any other questions.
Phil
2answers
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
