SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
SOURCE: Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
SOURCE: Power problem with Sony Bravia 40 LCD TV
hello my friend, check the power supply first, probably a fuse,but if the fuses are good you have to call the repairman.
ps. i have the same tv brand new in the box with the screen broken so if you need any parts let me know
[email protected]
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
