I need to replace theUtilitech model # 3125 Impeller and Diffuser Kit #B
SOURCE: Removal and installation of diffuser and impeller kit
All jucuzzi pumps are some of the most difficult to repair.Pump front should seperate from body(volute) of pump by means of screws, or some kind of band. Diffuser should have ss screws, or
be held in plsce by notches or both. Impellor spins counter clockwise to come off. Can only remove impellor with impellor wrench, or very strong hand. Rear of motor must be held in place with normally a 7-16 wrench, allen head wrench or screwdriver. Depends on manufacturer of motor. Then impellor can be removed!
Should replace shaft seal under impellor. Can seperate body of pump from motor by turning four outer bolts on back of motor. Must mark rear cover of motor so lines up exact for reassebly. Ussually 1/4 inch socket wrench.Seal can be pushed out from back to front with the corrrect size socket and a very light hammer.
Try to factory Jacuzzi seal, they are better than aftermarket.
Coat rubber on seal with light silicone, and press back into place without touching or marring seal face. Best way is use other half of seal (spring piece) to gently but firmly reseat seal. Examine body from rear to make sure seal seats. Reassemble as taken apart, or just take to a qualified service tech at a well established pool/spa place. Kirk
pump impeller and diffusers are available from any pump repair shop
find the brand name of the motor /pump ( onga, davey or the like ) and find a pump shop that handles that brand and they will have what you want
