Nokia E72 Smartphone Logo
s
shahin mohamed Posted on Jun 07, 2016
Nokia E72 shows star=up failed when switched on
2 Related Answers
Anonymous
  • 102 Answers
  • Posted on Apr 27, 2011
SOURCE: Dear Sir, Accidently, I installed the
Try to remove your memory card first and turn your phone on. If the problem still occurs, press the key * + 3 + Green Button together and hold that then Press the power button. This will reformat your phone and all data on the hpone memory will be deleted. Make sure you have enough battery charge to complete the procedure. Good Luck!
Anonymous
  • Posted on Sep 27, 2012
SOURCE: Nokia e72 mobile display showing white
nokia e72 display whait show
How to activate 3G in nokia e72 idea
i have a e72 nokia mobile and when i send a video through bluetooth then failed message or unable to play that video what should i do plzz tell me in details...........
2answers
1helpful
4answers
How to get unloced nokia e72
You can get the UNLOCK CODE at here
Simpleunlocking.com
and get the Phone Unlocked from Network lock,You can follow the instructions below and unlock it step by step...
Nokia E72 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia E72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E72 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E72 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E72.
3 - Compose #pw+CODE+1#.
4 - The Nokia E72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E72
It does not allow me to use any sim except t-mobile
Sure it's locked to Network You need to Unlock it,..so that you can use the Phone in any Sim that support GSM Technology,you cannot unlock from CDMA Network Lock,You can get the Unlock code from here
Theunlockspot.com and Unlock it,after Unlock it use it any GSM Network Sim card...T-Mobile can be Unlocked Because it;'s GSM Network ..You can follow the instructions below to enter the code correctly in the Phone...
Nokia E72 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia E72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E72 mobile phone, your phone may get hard locked and sometimes become unusable.
1helpful
I AM UPDATE MY NOKIA E72 MOBILE SOFTWARE FRAMEWARE BT WHEN START UPDATE SUDDENLY MY MOBILE SWITCH OFF THEN AFTER I TRY TO SWITCH ON BT ITS NOT START SO WHAT CAN I DO GIVE ME SUGGETION
that is software update problem try to connect it to pc & try to update one more time it may get up date but while update it may get restart 2 to 3 times if it says that update failed then you should Visite your Nearest Nokia Service Center (Nokia Care) They will update your Software or Renew your Software.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
2helpful
E72 Nokia message coming as Start-up failed.. contact the retailer... What is this problem.. & how to fix it..
why e72 nokia message coming not appear name my contact, whereas the contact name is available
2helpful
My phone start up is failed.how to solve it?
try to start your phone without memory card,if its not work then format your phone press star and green (call button) and 3 button and then press your phone power button together don't release these buttons until format complete and you see nokia logo
4helpful
How to enter "_" in Nokia e72
There's no shortcut or a dedicated key to type _ in Nokia E72, you have to press "*" (star) and select it. When you press star while entering the texts, you'll see the available special characters. Use left-right and up-down key to locate and press "Ok" to select it (it will be entered automatically on the position where the cursor is located/placed).
Good luck.
Thanks for using FixYa.
1helpful
My nokia e72 volume control doe not work, also
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
2answers
I have a Nokia E72 with WLAN as a built-in feature. How do I use this feature?
Whenever I disconnect the E72 WLAN (already in connected WLAN mode), E72 will reconnect WLAN again automatically within 1 second.
MANUAL
http://europe.nokia.com/find-products/devices/nokia-e72/specifications
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
