The White plastic bar that holds the spring attached to the moving blade in place, has broken, can you get them or may be a repair kit
SOURCE: Where can I buy spare parts?
http://www.gpsw.co.uk/cats/cl3_224.html try that one or ebay parts
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
SOURCE: Cutting blade doesn't move
a homelite is disposable, get a new one. You can pull it apart and see what broke and how much the new parts are. worst case, get the new one.
SOURCE: Door lach/handle plastic pins have broken off and
handle was redesigned with a metal rod through the attachment points to prevent breaking. the handle and latch comes as a complete assembly (you don't have to put it together).
SOURCE: I have a 22inch Craftsman Hedge Trimmer, Model No.
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
