Televison & Video Logo
A
Anonymous Posted on Jun 01, 2016
Picture in picture , how do I work it - Televison & Video
L Pfaff
Level 3:
Top Expert:
  • Televison & ... Master 11,573 Answers
  • Posted on Jun 01, 2016
L Pfaff
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3586915
Points
181713
Anon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do use picture in picture PIP on my LCD TV
Displaying picture in picture PIP
How to Use Picture in Picture
PIP
2answers
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
When I take a picture,it does not appear anything.
when I take a picture, the only thing I see in the image are horizontal lines and no picture.video camera is working fine.
Ontelligent eye not working
  • Has the I.S. (Intelligent Sensor) ever worked?
  • Did someone make changes in the Picture Menu and now the I.S. is not working?
Sometimes the changes the IS makes are so small you cannot notice, but the I.S. is working.
LG’s “Intelligent Sensor” uses 4,096 sensing steps to evaluate its surroundings. Using a
sophisticated algorithm, the LG processes picture quality elements including brightness, contrast, color,
sharpness and white balance. The result is a picture optimized for its surroundings, more pleasing to
watch and which can also save up to 50% in power consumption.
1. You can go into the Menu, Picture Menu, and then Advanced. From there you can fine tune all the picture settings.
2. You can also try a Picture Reset. Inside the Picture Menu, you can perform a Picture Reset. The Picture Reset returns the “selected picture mode” back to the default factory setting.
3. If all the above fails then the problems are between the Main board (process the picture parameters) and the Intelligent Sensor (is reporting the surroundings to the main board). Either one of these issues will require new parts.
Good Luck.
2helpful
2answers
G1 Pictures Messaging
It should be picture size issue. -Take a Picture -Open the picture in the picture browser
-Crop the picture (Can select the entire picture if so desired)
-Save
-Send the newly cropped picture in an MMS . Downsizing the image to 50-60kb. . should work.
No picture in a picture
The picture for picture-in-a-picture must come from somewhere. Try a DVD for the picture in picture. It may be the second tuner for the picture in picture that has failed.
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
1helpful
2answers
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
