There is a built-in dvd it also won't take a disc when you press the on/off button the standby light turns yellow then in split seconds turns red again,what need to be changed from which pc board? thanking you in advance for technical advise
I do not know specific on this model (which youdid not give a model number)
The most possible cause is capacitors which fail but also other parts or software issues can be at fault. Sets like most modern types have a start up routine which verifies sections of you set are working correctly before fully powering up, so if a fault is found just shut down.
There may well be a known part or parts but sets are made with components fitted by passing through "ovens" to make solder joints, these are at higher temperatures than normal tin/lead and standard irons are mostly not able to melt it without damage to track etc.
My advice is to contact Thomson (French electronics giant) for their nearest service agent a far better solution than to try yourself, many of the "thin" sets after a couple of years (out of guarantee) are not fixable because they require panel changes which soon run out of stock if many go wrong, sad but true.
Hope this helps........
