My garmin gps 1260 only loads on logo.
This is a booting problem. Please see this video that we have made that will explain why it happens and how to get the problem resolved. Garmin GPS Booting Problems By SHARCNET USA
SOURCE: garmin nuvi 5000 wont turn on.
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
SOURCE: unable to find free down load for owners manual
go to this link and download the manual from garmin free of charge there are also links to update firmware etc also.
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
if this answers your query please rate me accordingly.
regards
SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This
tip will describe how to perform a hard reset of the device, and how to
backup your 'Favorites' in case the hard reset erases them.
A
hard reset (or Clear All User Data)has been known to resolve unit
quirks and strange behavior after firmware updates. It's generally
recommended to perform it after a firmware update but is not required
by any means. However, if you're seeing quirks and strange behavior
with your unit after the firmware update, it is a good idea to do a
hard reset of the unit. It's also one of the first things that Garmin
will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
Ifpossible
after the hard reset, let the unit sit outdoors in the open for about
30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
SOURCE: My Garmin nuvi 780 will
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Call at Garmin Customer Care Toll Free Number 1-844-313-6006 to get quick solution.
