When the rinse cycle starts, the display showing like its restarting.i have replaced the relay board but still the same problem .please help.
SOURCE: Rinse cycle has no water
check the sump probe under the screen and the 2 probes in the right back corner.clean them with a light grit sandpaper.let me know.
SOURCE: LXIH, ML #130017
hi there have you checked that the drain pump is pumping out the water fast ehough, sounds like you may have a blockage problem and the programe is timeing out ie. not draining within the specified time, for example 3 mins
SOURCE: hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
SOURCE: hobart lx18 no power to detergent pump, during the
you have to go into program and activate the detergent pump.sounds like somebody deativated the det. program
