Removing the center pulley assembly from a Kubota deck RCK54-24G will require some specific steps, and tools, as well as some knowledge of mechanical systems. Here are some steps you can follow:
- Park the machine on a level surface and engage the parking brake.
- Remove the belt cover by removing the fasteners or clips that hold it in place.
- Remove the belt by releasing the tension on the idler pulley and slipping it off the pulleys.
- Use a socket or wrench to remove the center pulley nut and washer.
- Use a puller or gear puller to remove the center pulley from the shaft.
- Clean the pulley assembly, shaft, and deck.
- If the pulley is damaged, it should be replaced.
- Reinstall the pulley assembly in the reverse order of removal.
- Tighten the center pulley nut to the specified torque.
- Check the belt alignment and adjust it if necessary.
It's important to follow the manufacturer's instructions and use the right tools and equipment when working on the machine. If you are not familiar with the mechanical systems, it's best to take the machine to a qualified Kubota repair service center, they will be able to diagnose and fix the issue.
