In order to delete a articular contact you have to go you may follow this s menu.steps. 1.From the Home screen, press menu2.Scroll to Contacts you want to be deleted, then press the Selection button3.Scroll to the contact to delete, then press Options4.Scroll to Delete, then press option.Contact should be deleted. Thanks
As you said me you want to delete some contact from you are phone memory means you can do this if you follow this things.Go to menu select contacts then scroll over to delete option and select that option after selecting that you will get two option telling delete all, one by one.If you select all contact will be deleted if you select one by one means you can delete one by one.If you want to edit the number means you can select menu and then contacts there you will get search select it and type the name after getting the contact select option then scroll over to edit number there you can edit.Thanks for you are question happy to help.
how to delete save numbers in phone? go to phonebook or whereever your contacts are. click the oprion button a nd find "delete". click on it to delete selected contact
In your contact lis, touch the icon to the left of the contact name which will place a check mark there. At the bottom right of your screen next to "GO TO" touch the option menu icon (looks like a piece of lined paper). "Erase" is the first option.
You can delete multiple contacts at once by selecting more than one contact before you open the options menu. A similar procedure is use to delete contact groups.
you need to go to your contacts click options or menu.... click manage contacts then delete... or if you dont have that go to contacts, names, options, delete contacts
you just go to "send message" option, then select "picture mail", then go to "recent list", click OK, then select the person you want to delete and click on "options" and click on "delete". It will then delete that person from your recent list. I just did this and it works.
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu > Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code. To delete a contact, search for the desired contact, and select Options > Delete contact. To delete a number, text item, or an image attached to the contact, search for the contact, and select Details. Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image. Deleting an image from contacts does not delete it from Gallery.
