For the Gardena-T-1030-1805 model....
Gardena 1030 1805 Operating Instructions Manual Page 7
11. Battery
11.1 Status indicator
If the battery capacity falls below a certain level, a warning signal sounds every 15 seconds. The programs you have set are not run. The water flow cannot be opened manually. If a valve is open, however, it will be closed.
11.2 Changing the battery
If the battery capacity is too low (the warning signal beeps every 15 seconds), you must change the battery.
To do this, the water timer must be removed from the tap.
Important : Changing the battery deletes the data you have set.
To change the battery :
1. Insert the battery in the battery compartment
2. Set the Run Time control knob
3. Reset the watering data as described in "Setting the watering data".
3 If the Run Time knob is not turned to Reset, 5 seconds after the
battery was inserted the current Run Time shall be accepted. This is confirmed by a double beep.
Note : The time the battery was changed is taken to be the starting time.
To ensure that the water timer works properly we recommend that you insert a new battery at the beginning of every gardening season, or at the latest after a year.
Important ! Please dispose of used batteries properly at the appropriate communal waste disposal site. Only dispose of batteries when flat.
SOURCE: Need manual for t14 gardena water timer 12 yrs old approx
Program Cycle Duration (minutes)
man On Once 30
1 4 times a day 3
2 Twice a day 3
3 15
4 Once a day 3
5 5
6 30
7 60
8 Every 2 days 5
9 30
10 60
11 Every 3 days 30
12 60
13 Every 7 days 60
14 120
Can't believe I saw this...don't usually go on the hunt on the net, but wanted to see if I could source some more of these. I, too, have had my timers for 12 years and swear by them...Excellent product...just happened to go out to the shed today and found the last surviving box, with instructions !!! Good luck, Fiona
SOURCE: gardena c 1060 water timer problem
Hi Cornwell,
I have timers similar to yours. Happens more often than I like to think about. Here's what I do:
Good luck and happy watering
Mike
SOURCE: where can i get a
oct 2110
I cannot find parts or manuals on Gardena products.
Gardena.com has a product page and a contact page
They have technical drawings for some products so parts must exist somewhere.
Gardena product page
Contact Gardena
If
you are looking for operation manual at Gardena, they only have sales brochures
and technical drawings.
SOURCE: I Have some Gardena T120 Water timers . We put
My Gardena T120 's timer isn't functioning well
Can this be fixed
I dont even see how to get into it
SOURCE: How do I programme my
The following link has some Gardena manuals, and resources:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Due to space constraints, we cannot write out the manual. Plus the manual has illustrations that are key to understanding your device.
Read the manual that applies to your specific product.
Then add a comment saying what part of manual is confusing and what you have done so far to get the water timer working.
If your manual does not show, add a comment with in-focus photo of timer that you posted on Flickr for possible identification and instructions.
If your water timer is not working, say what you have done so far, and maybe more information can be added. Broken water timers have low probability of functioning again. Gardena shows a parts link, but as of right now, I do not know who sells parts, and am actively seeking that information.
Folks can add a comment about parts and repairs they have verified and keep this thread current.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
