Hello, I have some vertical lines on my plasma TV. They are multicolored and intermittent. They are located about 4-5 inches from the right edge of the TV (always in the same place) and are approximately 2-3 inches wide. The research I have done so far suggests that I need to change a buffer board (x-axis) but I'm not sure if this is correct. I have an image of the problem if you need it. thanks, Alex
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
