Camper ? grey water is used water tank from sinks and showers the gauge I guess is an indicator to show how full tank is (I never had a gauge to tell me), if camper is large then yes it could have two tanks , I will say if there under floor , and you move camper a lot then its best to maintain a even level in both tanks, no sense to make one side heavier than other , remember water is 8.33 pounds per gallon so it wont take too much difference to unset the balance of camper on the road
SOURCE: My 2008 road king has an annoying whine when I
Your transmission has a straight cut 5th gear and not a helical cut 5th gear.
HD fixed this whine with the 2010 touring models.
SOURCE: Can I put factory 2008 Road King spoked wheels on
You will have to measure your tire width and the frame width for the rear tire as Harley went to a wider rear in 2007
We dony know if one is actually black water or what.. we only have freshwater meter grey1/ grey2 and holding meyers.
in that case I suggest u rename one gray and one black(toilet connection)dmp out stations will require one to prove they are separate b4 u dump any (makes things harder 4 them to deal with it and besides there are separate dump rates for black and grey water tanks so its cheaper 4 you too)
