SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: My hobart champ 140 won't idle up during welding
hi greg:i dont know if i under stand this problem but ill try.theres only a couple of things that can really go wrong so well try those first ok.1st the ground is bad try moving it to a better spot on the piece to be welded.2ndtry to re adjust the wire flouwer in the machine.or on the machine3rd make sure the wires moving the way you want.ok!i tried hope this helps jojogunn
SOURCE: need manual for Hobart 500416
Hobart has a wonderful site. Go to hobartwelders.com click on service/products and then manuals.
Paul
SOURCE: Have a hobart 140 mig welder, the wire feed otor
I have a 120 and when that happened to it the bridge rectifier was bad on it. Not sure if your 140 has that or not but just something to look into. It only cost me about 8 or 10 bucks to fix mine.
SOURCE: my 140 mig welder the
http://www.airgas.com/
These guys can get parts for any welder. Contact their service dept.
Hi Kevin Thomas, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
what have you plugged power cord into is it directly into power point or via a power board with surge protection.
Also how good is the welders earth connection on the item you are welding ?
