Check the pins in back there should be two pins in the back or under the seat that you pull out to push it around your garage or whatever and the should be pushed in to mow. that seems to be a fun trick to play on people around here.
Testimonial: "i just removed the fan covers and found serious play in the belt, 6" or more, removed rear tire to inspect, looks like the slack adjuster is not doing it's job, i am going to replace belt and hope that works looks a little worn 3 years old thks"
