SOURCE: scanner
this happened to me yesterday after recieving whatever lexmark update my computer downloaded. I restarted everything, computer and turned on/off fax and unplugged for a bit.
It seems to be working OK now.
I know that's lame dell-style, advice, but the restart worked for me.
SOURCE: cannot retrieve application list on scanner
try boosting the power couplings followed by initiating the inter-active recipter valve. Once you see the deflanger code type in +.ak234//pp.HO.
This open up the transducer allowing the flow of typherical codes that was being block preventing you scanner from downloading the application list.
If this doesn't work, write your Congressman.
SOURCE: lexmark x5470
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
937
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
